1 members (dt235sd), 60 guests, and 1 robot.
Topics128,080
Posts1,055,956
Members48,430
#47996 07/20/2005 3:28 PM
Junior Member
Junior Member
my "new" '56 3800 flatbed has a '57 283 and I need tune-up info, since it's been 30 years since I've worked on a chev...is there a book available with this info, or can anyone help me with gap, timing, carb specs? the isual books I have seen do not have this info...Thanks, Frank
#47997 07/20/2005 3:39 PM
points .019 new, .016 used
timing, start w/ 8° before
dwell 26-30°
idle 450-500 rpm , mix for highest steady vacuum
#47998 07/20/2005 3:44 PM
Junior Member
Junior Member
thanks Bill, that will get me going in the right direction...Frank
#47999 07/21/2005 3:49 AM
V
V Offline
when in doubt on the points if it will run turn the adjustment screw clock wise till it misfires then back it up 1/2 turn this will put you within the recommended dwell specs 28 to 32 degrees. if you have a dwell meter set it aas close to 28 as possible as the dwell increases as the points wear.
