Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
4 members (joetravjr, Guitplayer, Paul Mullen, 1 invisible), 568 guests, and 1 robot.
Topics126,780
Posts1,039,294
Members48,100
Most Online2,175
Jul 21st, 2025
#478860 12/05/2008 7:34 PM
Apprentice
Apprentice
1 Offline
Hello,
at the moment I am installing the headlights at my 1952 Chevy. In one of the boxes which came with the car I found "headlights ring rubber seal retaining wire clips" like you can see here : http://www.oldchevytrucks.biz/47_55/full.asp?page=65 But : How and where have I use them ?
I have also a problem with the brand new headlight chrome ring. At the bottom there is a hole for the screw to hold it at the bucket but there is no hook or so to fasten it at the top of the bucket.
Can someone help me ?
Thank you.
Tom
Ex Hall Monitor
Ex Hall Monitor
On my 38 one style holds the reflector in the housing and the other holds the lens in the bezel.
Tom,
I think your chrome rings are sort of like my 46.
The rubber seal goes into the chrome ring where it contacts the headlight. The spring clips are used to hold the seal in the chrome ring. One of the spring clips is bent such that it leaves a portion of it hanging down that you hook into the slot at the top of the headlight bucket. Then screw it in at the bottom.
Hope this helps
George
Apprentice
Apprentice
1 Offline
Hello,
thanks for your answers.
@ George : OK, I understand... hmm, is there a photo around where I can see it how it works ?
Thank you
Tom
1949 Chevy 6400
1931 Chevy Firetruck
Apprentice
Apprentice
1 Offline
Hello,
ah, then I was on the right track. Thank you. And... I have too less clips...
Regards
Tom
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 2.465s Queries: 14 (0.117s) Memory: 0.6143 MB (Peak: 0.6652 MB) Data Comp: Zlib Server Time: 2025-09-22 19:17:28 UTC
Valid HTML 5 and Valid CSS
