| | | Forums66 Topics128,078 Posts1,056,021 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2007 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2007 Posts: 37 | I have a 1935 chevy 1\2 ton, the 207 engine was not useble and I was able to pickup a good 216. the bell housing for the 207 will not fit the 216 so I picked up a another housing. The rear engine mounts for the 37 housing are much different then the ones for the 35..It looks like the rear frame mount cross member is different. Anyone know what needs to be done to fit the bell housing to the old frame so that everything will line up? | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | The 35 mounts should fit the 216 bellhousing
See the USA in your vintage Chevrolet! My Blog | | |
