4 members (FAST55, tclederman, Oswald, 1 invisible), 52 guests, and 0 robots.
Topics128,075
Posts1,055,918
Members48,429
#478121 12/04/2008 2:30 AM
just wondering if any fellow bolters have ever removed the roof cap on a 60-66 style truck...i have a 62 and water has gotten in around the rain gutter over the years and it's rusty in between the roof panels. i would like to try to remove the roof cap and sandblast the rust around the upper windshield area, then paint it with por 15. i know i need to cut out a hundred spotwelds...any advice would be helpful
In order to remove the roof cap on a '60-66 Chevy truck you will need to remove the factory seam sealer in the drip rail, around the perimeter of the roof. This will expose the factory spot-welds. With a nail set or center punch, hit every spot-weld, then you can drill out each spot-weld. I prefer a spot-weld cutter, because it only cuts through the top piece of sheetmetal, thus leaving a solid piece to weld to.
Once all of the spot-welds have been cut, the top can be removed. With a little coaxing, it will pull away from the adjacent sheetmetal. After removal, it will be obvious where the water penetration has occured. At this point, you can do the remedial work to allow the top cap to be replaced. Finally, make certain you install a suffucient amount of seal sealer, to ensure there is no further moisture penetration, at the drip rail. This area is a historical location for moisture weaping, so make sure you do what is necessary to avoid this in the future.
well, i won't have any problem with seam sealer...dosn't look like it ever had any! i can see why they did away with that design after 66, it is a watertrap, not good.when i am done i will fill that sucker up with the best seam aealer i can find...thanks shop shark
