| | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#47788 07/17/2005 9:33 AM | Joined: Feb 2002 Posts: 61 Member | | Member Joined: Feb 2002 Posts: 61 | This might be a "dumb" question.....
I know that the early Chevy engines were splash and then became full pressure....
My question is, were the 228 engines the same way? Originally splash or was it always full pressure? :confused:
My 52 GMC pick up has a cracked block (cooling jacket is cracked near the drain hole on the block) and I sort of tracked down a 1939 228 engine.....
Thanks!
1948 Dodge 2 ton 1950 GMC 1 1/2 ton 1952 GMC 3/4 ton
#47789 07/17/2005 11:16 AM | Joined: Mar 2003 Posts: 313 'Bolter | | 'Bolter Joined: Mar 2003 Posts: 313 | The GMC engine was a full pressure engine. | | |
