| | | Forums66 Topics128,021 Posts1,055,373 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#47429 07/08/2005 7:28 PM | Joined: Mar 2005 Posts: 197 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 197 | Does anyone out there know how to deciper this number off of what I presume to be a GMC 228 engine? The number stamped onto the block is as follows: A228293305. I just need to confirm that it's a 228. It's definitely a GMC with the old GMC script logo on the valve cover and about 5 other places, including the head. Just need to know what I'm working with here. Thanks, Neil
Neil 1940 GMC 1/2 Ton
#47430 07/08/2005 9:49 PM | Joined: May 2003 Posts: 328 Shop Shark | | Shop Shark Joined: May 2003 Posts: 328 | It is for sure a 228. That is evident by the first 3 numbers in the numbers you provided.
Hope that helps.
Phil
Never hold your farts in. They travel up your spine and into your brain...that is where crappy ideas come from.
