0 members (),
79
Mod | | | Forums66 Topics128,021 Posts1,055,373 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 206 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 206 | Well a few years back I built a press using stuff I had laying around.,electric motor driving a pump.The pump put's out 2000 lbs.I used a 2" ram,9" stroke.Well as far as I figure it's only at 4000 lbs at the ram.2000 lbs per square inch equals 4000 with the 2 inch ram? I've pressed some pretty stuck stuff and it seem's to work great but I'd like to up it a bit.I'm thinking of a 6 to 9 inch ram.Any thought's? Or is my math wrong?Tom
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Tom,
PiR2 is the formula for the piston surface. I got 6.2832 sq inches times 2000 psi. This equals 12,566 lbs of oink! I'm not a math major so this might be defective.
That's a respectable amount of push for a home shop press.
Stuart | | | | | Joined: Jan 2008 Posts: 4,960 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,960 | Maybe things changed by when I was in school PI was 3.14, the radius of a 2" ram is 1" 1 squared is still one times PI = 3.14 times 2000 = 6280 PSI. I changed my major from pre engineering to accounting and pre law. Maybe it was because I was dumb. And I got my degree over 40 years ago. Lots of brain cells have died off since then. | | | | | Joined: Sep 2006 Posts: 206 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 206 | Thank's for the replies guy's.But I'm not anywhere near a math whiz,So I'm either at 6.280 lbs now or 12,566.hmmmI'd like to get 20.000 lbs out of it.It's built out of 2x4 tube steel,heavy wall.reinforced it up top with 4 inch channel and mounted the pump and tank up top out of the way.1 inch pin's holding the deck.I may be going to the storage building today and get a pic.Tom | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | by 2" ram do you mean the piston bore size [cylinder] or the rod? Force=Pressure X Area of the piston at 30,000# [2000psi on two 5" cylinders] I bow the uprights on strongbacked 4x12 I beam, 2x4 tube might kill someone at 20,000 .... Bill | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | HEY....1 X 1 doesn't' equal 2...sheesh, I told you I was dumber than a post! Sorry grub, Crenwelge is right. Stuart | | | | | Joined: Apr 2000 Posts: 499 'Bolter | | 'Bolter Joined: Apr 2000 Posts: 499 | I built this one out of 4" Channel. The 12 ton bottle just sits there with a pocket for the bottle's ram to center it. The bottle can be just pulled out and a 20 T set in its place if there was ever a need. The ram for the press, below the bottle is in two pieces. The 1" piece can be removed and push with the larger 1 9/16" section. Only the table is welded and is supported by two 5/8" pins on both sides. The rest is bolted with 9/16" grade 8 bolts and with the 12 T has not failed me. Press
'67 GMC 3/4 292 4spd
| | | | | Joined: Jan 2008 Posts: 4,960 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,960 | Getting back to the original question, the length of the ram has nothing to do pushing power. If you are talking about a 6" to 9" diameter ram, you will have to rebuild your whole contraption because you will be dealing with 56,000 and 127,000 lbs of pressure. When you square the radius, you get up there in a hurry. We have a 100 ton press in our shop and it so big it takes a fork lift to move it and there is nothing on a pickup that requires that kind of press. | | | | | Joined: Jan 2006 Posts: 586 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 586 | You do nice fab work.Two weeks ago I was able to get a tour of an old machine shop with the shafts and drive belts in the ceiling (circa 1900).They had a "home built" 250 ton press with a brass pressure gauge, in the back of the shop.With 500,000 PSI,I could really get into trouble!!
Wanted Good Woman: Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
| | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | A very easy piece of equip. to weld up,in the shop.A few pieces of channel iron a good drill press to make some large holes for table height adjustment plus a hydraulic bottle jack.And Viola,youve got a hydraulic press. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I may not be an engineer, but I have seen and used a number of different hydraulic presses, and I don't think you want to go with a larger ram. The frame looks like it may or may not just be enough for the setup you have now. One shop I worked at someone was pressing something supported in V-blocks, one of the blocks exploded, that was not a good picture. There is a lot of force involved, and if something fails it can be quite dangerous, don't take any unnecessary chances. You could buy a really nice commercially built press for less than a hospital bill..
Grigg | | | | | Joined: Apr 2000 Posts: 499 'Bolter | | 'Bolter Joined: Apr 2000 Posts: 499 | If you go look at some of the cheap chinese crap on the market you will see that they supply the presses with cast iron blocks. Those cheap cast blocks will split apart like glass before they will bend.
| | | | | Joined: Jan 2008 Posts: 4,960 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,960 | If the one you built in the first place works for what you do, why mess with it. If you more power, get a little bit bigger ram, but then you will need a stronger frame. The presses with bottle jacks work fine, but they are slow, especially when you get into a 20 ton jack. Our 100 ton press has 3 speeds, either air over hydraulic or manual pumping. Several years ago we built an oil filter crusher out of a pump similar to what you have. We crushed a filter with our hydraulic press to figure out how many tons it took to crush a filter and then bought a ram with the proper diameter and stroke. It works like the new $2000 kind with only a $200 ram out of pocket. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Agree wit ya Grigg, the first thing that jumped right out at me when I heard talk of a bigger cylinder was that three inch channel at the top. Won't take much more in that wide of a span than what you already have on it. Of course you could always bring gussets down in the corners but it would be just as easy to go to a four inch channel and have done with it. Denny Graham Sandwhich, IL
Denny G Sandwich, IL
| | | | | Joined: Sep 2006 Posts: 206 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 206 | Yup 4 inch channel it will be then,and a plate.I've decided to go with the 3 inch ram so it'll be better than it is now,but not to dangerous,I know, I've seen thing's come out of presses,and they fly out quick!Safety first! | | | | | Joined: Apr 2008 Posts: 30 Apprentice | | Apprentice Joined: Apr 2008 Posts: 30 | i dunno about you guys but we have a huge one, 4'' piston with 24,000 lbs capacity, i ought to put some pics up, its worked flawlessly since my dad built it back in the 80's
--<Spence>-- 1953 JT 1947 chevy 1 1/2 ton
| | | | | Joined: Sep 2006 Posts: 206 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 206 | Yeah young guns,put a pic up! | | |
