8 members (HandyAndy, 52Carl, 55shaker, Cosmo, RoadsScholar, Jay R, Ponchogl, 1 invisible),
76
0
Mod | | | Forums66 Topics128,049 Posts1,055,629 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2004 Posts: 425 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 425 | Does anyone know of a company reproducing STEEL running boards for a 3/4 ton Chevy(49)? Or, if not available, where could I find a very good used set? Thanks. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | For a used one, place a Want Ad in the Swap Meet.
| | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | I feel your pain. I'll probably have the center portion of mine plasma cut out. Then have someone bead roll some sheet metal and I'll weld it back in. Another option is to buy some 3100 boards and graft them together, but that could get pricey since you'll be buying two sets. | | | | | Joined: Aug 2008 Posts: 7 New Guy | | New Guy Joined: Aug 2008 Posts: 7 | I have a pretty good set of 1949 chev 3600 running boards...in fact I have the frame, engine, 5 speed tranny...really everything. I took the body off and putting it onto a 1988 S10 and will not reuse the running boards or any of the drive train. frame. Male an offer | | |
