4 members (Otto Skorzeny, dt235sd, Peggy M, klhansen), 85 guests, and 3 robots.
Topics128,088
Posts1,056,390
Members48,442
Apprentice
Apprentice
Hello All,
I recently purchased a 8K original mile 49 & 53 Chevy COE. I am a new rookie to these trucks. I want to make the 49 a SAFE and dependable weekly driver. What should I check/change to make it SAFE and dependable. Thank you in advance for all your help.
Don Jr
[email protected]
413-246-8452
Agawam, MA
The first order of business is to educate yourself on these trucks. You've come to the right place. Be sure to check out the tech tips. Then go through your brake system.
With that low miles you should be very close to having a safe and reliable truck as is.
Go through all the brakes, replace all the seals and cups in the wheel cylinders, and be sure the shoes are thick and dry.
A complete service, grease and oil for everything that uses it.
One upgrade I would consider first is a modern brake booster with most importantly a dual circuit master cylinder, sized properly for your large brake system. The dual circuit MC is very much worth the extra factor of safety.
I drove my mostly stock 52 1 ton every day for a few years, never left me stranded, unless I ran out of gas... Later I added disc brakes and PS, but still a 1955 235 and 4 speed, it took me and a friend 8,000 miles in a month, from coast to coast. These trucks can be fun and reliable daily drivers, a number of other Stovebolters here have similar stories to tell. After all, these trucks were new once.
Be sure to get an original/reprint service manual if you don't have one already, and read it from cover to cover, or at least look at the pictures and read a few lines here and there, then when you need to know something you'll have an idea where to look.
With a low mile original truck, best to keep it original, but if you find you need a new or different engine then a 261 would be somewhat close to original in appearance, and a little more reliable and or less maintenance than the old style 235 or 216 you likely have. Most folks consider this an acceptable upgrade even for a mostly original truck. Nothing about the swap can't be undone later, it doesn't have to be permanent.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
One other thing that is very important is to post pictures! I think we would all like to see!
Red meat is not bad for you.........Fuzzy green meat is bad for you!
"What happens in the garage stays in the garage!"
1958 Chevy Spartan 100 firetruck in the Gallery
