4 members (Steelonsteel, FishinToms53, Gdads51, 1 invisible), 126 guests, and 3 robots.
Topics128,045
Posts1,055,528
Members48,424
#471814 11/15/2008 9:57 PM
In side my Harrison radiator there is a baffle that is sliding back and fort in the top part of radiator. This is moving very freely so is this made to do this or is it to be fixed to one place?
1951 Chevy 3100 Deluxe 5-window
Four generations and still not for sale!
More pictures in Photobucket
David
I don't think the baffle plate is meant to move,sounds like a couple of spot welds have come adrift. The plate in mine seems fixed in place.
Maybe someone else will chime in and confirm this?
It might be worthwhile contacting a local radiator repair shop to get their opinion too.
More pix on Flickr.
Can you tell the location where yours may be fixed? I’m thinking either in the center of the fill hole or may be in the center of the top hose opening.
David
I just had my radiator repaired at a local shop. My guy said Harrison is the brand name of the tank on top of the radiator(not the radiator as a whole). I'm not sure if this is true or not but he did say there should not be any baffles moving inside.
Tango - yer rad guy must be pretty young, Harrison Radiator was a division of GM until not long ago, and made all the GM rads from the teens on .... but he's right that there's no moving parts in a radiator grin
If an original Harrison radiator has been recored with a non Harrison core then the "young" radiator guy would be right, only the tanks on that radiator would be Harrison. Perhaps that's what he was getting at?
Otherwise I too thought Harrison made the whole thing.
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
Y
Y Offline
My radiators are harrisons' and they both have a baffle just to the bottom of where the top radiator hose comes into the radiator- they are fixed into position and Can't tell you exactly what they are for except to help direct flow-
They are brass plates brazed in place.
1949 Chevy 4400 Big Red
1949 Chevy 3600 Bob's Truck
1949 Chevy 3100 The Investment
1949 Chevy 3800 the Won Ton
