4 members (dt235sd, Rich'sToys, wilbur53, Stovebolt48), 173 guests, and 3 robots.
Topics128,115
Posts1,056,288
Members48,439
Page 2 of 2 1 2
Pull the drum off and get rid of the backing plate. A rotor should slip right over top. I was on Chevsofthe40's and they have added alot of new roller bearing applications. You may even be able to find the right one.
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
OK guys, why could we not use the 1.625 ID bearing that comes with newer rotor, and get a sleeve for the spindle?
ABS bearings has a sleeve pn cb2426-16 that is ID 1.50 and OD 1.625. Would this work for inner bearing?
bump any updated?
Page 2 of 2 1 2
