BUSY BOLTERS Are you one? The Shop Area
| | Click on image for the lowdown.
| | Forums66 Topics126,777 Posts1,039,267 Members48,100 | Most Online2,175 Jul 21st, 2025 | | | Joined: Nov 2008 Posts: 8 New Guy | New Guy Joined: Nov 2008 Posts: 8 | What is the best oil use in an old 'bolt. Synthetic or "old fashioned" I'm concerned about wear on the cam and lifters and I've heard that the amount of zddp is being reduced in modern oils which will lead to accelerated wear on components. | | | | Joined: Aug 2005 Posts: 6,383 Ex Hall Monitor | Ex Hall Monitor Joined: Aug 2005 Posts: 6,383 | Do a search using "oil" in the search field. This has been discussed a LOT. You'll find hours of informative reading.
