| | | Forums66 Topics128,034 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2008 Posts: 39 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 39 | i have a 36 pickup with a fuel gauge that shows empty all the time. in the manual fuel gauge troubleshooting section it says to diconect bayonet socket just ahead of fuel tank, when i did this my gauge went to full. manual says this means wire from gauge to bayonet socket is ok but the tank unit is shorted and must be replaced. what exactly needs to be replaced? the sending unit or just the wire or something else? and where can i buy whatever needs replacing? thanks guys.  | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | christian s,
I think this is telling you the sending unit is shorted, or in the case of a '36, maybe 'rotted' to ground. The wire to the gauge sounds fine as disconnecting the sender affects the gauge.
Where to get a sender...I don't know. If it's easy to get out, I would pull it first and look at it. Maybe some creative work could revive it.
Stuart | | |
