0 members (), 40 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#47157 07/02/2005 3:09 AM
Can anybody suggest a syncro 4 speed trans that would bolt up to a torque tube in a 39 pu? Trying to stay some what original with a little more performance.
#47158 07/02/2005 2:29 PM
I dont think changing trannies is going to help performance,unless you go to an overdrive unit.Your rearend gears are what needs to be changed.Gotta get that gear ratio down around,maybe 3:55 or 3:73.That would give you better top speed.
#47159 07/02/2005 5:41 PM
Do you have a 3 or 4 speed now?
The 4 speeds are non syncro in 39 but the 3 speeds are, they are much easier to shift fast.
There are no syncro 4 speeds that will bolt in without some conversion work.
My Blog
#47160 07/02/2005 6:15 PM
k10 Offline
As Dale said, you might want to check Patrick's for a 3.55 ring and pinion. I swapped my 3 speed for a non synchro 4 speed and have the 3.55's. It's not a truck you wife would drive, but I like it that way. Double clutching all the way. Makes a nice whine and very satisfying to drive correctly. Call Patrick's. He has a torque tube adapter kit to put a saginaw tranny into a 48-54 1/2 ton. Maybe you could get a newer bell housing, saginaw, torque tube........ but the again you have to change the pedal arrangement. Back to square one. eek
#47161 07/03/2005 5:22 AM
There have never been any all synchro 4 speed transmissions with connection to a torque tube. Last torque tubes were 1954, the first all synchro 4 speeds were late 1957.
#47162 07/06/2005 7:11 AM
Thanks for all the great imput guys. I currrently have a 4 speed and was already considering changing the rear ratio to a 3.55 I'm probably going to rebuild my 4 speed to avoid changing the pedal and emergency brake mounts but the 3 speed syncro is also a good thought. I do occasionally like to creep around in the granny and would probably even use it more with the 3.55 rear. Trying to decide if I'm ready to give up my granny. Does anyone know if helical cut gears could at least be used in the old straight gear 4 speed? Thanks for the ideas.
#47163 07/06/2005 7:40 AM
Patricks sells an adapter to fit a torque tube to a Saginaw.
Baldy
#47164 07/07/2005 6:26 PM
google up http://www.smokemup.com/ ... go to auto math
to correlate your rear end drive, tranny and RPM.
get a 10 or 12 bolt for that old rear end, you can change all you want of that tranny but the rear end WILL limit your top end speed
gooday
Jim & Caroline
