0 members (),
132
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,285 Posts1,058,276 Members48,483 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2007 Posts: 31 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 31 | Does annyone know where I can get some 0.100 or 0.125 pistons for a 261 chevy? | | | | | Joined: Sep 2008 Posts: 125 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2008 Posts: 125 | Patricks sells .080" max. If you want bigger you probably have to order them from a custom manufacturer like Ross or J&E or Wiseco, or similar companies. I would leave some rebuild room in it, and anyway you should sonic test for those kinda bores! Coreshift could easily cause you to ruin your block @ .100" over
Who is John Galt?
| | | | | Joined: Apr 2007 Posts: 31 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 31 | It looks like this one is going to get a set of sleeves, that will leave room for future rebuilds. | | |
