2 members (Peggy M, 59 fleet),
87
Mod | | | Forums66 Topics128,096 Posts1,056,489 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 126 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 126 | Need a tandeam axle of the era for the 1946 2ton. Any knowledge of location or tech information. | | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | I don't think Chev offered a tandem in those years unless it might have been something for the military and those are bulky expensive to maintain setups. A Hendrickson walking beam tandem was offered on bigger trucks and they changed very little from the 40's to the 70's. Hendricksons were pretty much standard in garbage trucks,mixer trucks and tandem dumps for many years. Even over the road trucks used them a lot until about the 70's. They came in rubber pad or spring. The rubber pad would probably be more period correct, but they really ride tough. I drove one in the late 60's.Most old tandem trucks,except for Mack, you see sitting around will have a hendrickson, but most will be on air. Finding one with hydraulic brakes is going to be tough. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy CAJUN CRAW FISH, a company named Thornton made a conversion for Chevies called a "Dual Drive", it used two standard Chevy diffs. with the pinions pointed at one another, the power came to them through a drop box, and therefore only one driveshaft. You could order the truck from the dealer, or there might have been a kit available, hope that helps. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | A member of ATHS, Gene Buchanan, in Wisconsin had some sort of unusual tandem setup from an old Chevy truck. It was interesting but confusing, looked like a lot of trouble to me, but I don't remember the exact setup, probably did have the two pinions pointing to the center of the tandem setup. I was there to pick up some other stuff, and he gave me a tour around his place. I don't know the whole story, but it sounds like he sold it but it was never picked up. It might be worth a try to call him. I don't have his number handy, but you can find him through the ATHS, he is, or has been, very involved. www.ATHS.orgGrigg | | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | I saw a truck like you describe in Hutch at the convention this year. May be the same guy. Those things were actually offered by Chev as oem for a couple of years in the mid 50's but they became obsolete in a hurry when Eaton and Timkin came out with through shaft bogies. Hendrickson walking beam suspensions must have been around in the 40's because I have some old Batco catalogs that list them and they look like there were very little changes from the 40's through the 60's. I just got through scrapping an Eaton 3 speed on a Hendrickson that had hydraulic brakes. I thought I was lucky to get $100 from a scrapper who winched it out of the weeds. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I did not notice a truck with that suspension in Hutchinson, but I was not looking either. The tandem Gene had was just a cutoff frame, no truck.
Grigg | | |
