2 members (fonz8261, 1 invisible), 128 guests, and 0 robots.
Topics128,119
Posts1,056,317
Members48,439
#47064 07/01/2005 12:00 AM
I am rebuiding my Rochester BC 1 barrel on my 235, the bottom flange of the carb that sits on the intake manifold has a small hole that is open to the interior of the carb, hoever, when the carb is bolted down on the manifold this small hole is covered and closed by the manifold gasket .. I seem to recall a post that said this hole was supposed to be open to the manifold ... anyone know anything about this? Thanks
1951 Chevrolet 3100 AD Pickup
JNash,
Yes, there is a hole (for vacuum?) in the base of the carb that hole should match up with a hole/notch in the carburetor gasket that also lines up with a notch in the carburetor-to-intake spacer/insulator.
Tim
Tim - Thanks for the response, I'll try opening it up and see what happens!
