| | | Forums66 Topics128,050 Posts1,055,646 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#46986 06/28/2005 3:09 AM | Joined: Apr 2005 Posts: 40 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 40 | When I bought my 58 Panel it already had a '67 Camero 327 in it. I was having problems with the accelorator pump in the carb so I got a rebuild kit and then with a new kit in the carb it wouldn't idle. So I bought a new 2g 2 barrel carb and it's better but I can still see gas dripping into the venturi's at idle. What am I missing here? The idle is around 700 rpm and the acceleration is good for this combo but the extra gas dripping in the carb is causing small backfires thru the headers when I lift the pedal. Should it be time I bought a rochester book and start looking at the pictures? Thanks.
Mike
In loving Honor of PFC Benjamin Gandalf Young 30 March 1988 - 27 May 2007 Sometime I wonder, Who you'd be today www.BENS58.COM | | |
#46987 06/28/2005 10:34 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You should not have gas dripping at idle. Check the fuel pressure. It should be about 4-5 lbs. Check for vacuum leaks. It may have the gaskets under the discharge nossels leaking. If is a reman. carb about half of them arn,t any good. you may have to return it.  They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
