3 members (Gdads51, Ponchogl, mick53), 39 guests, and 2 robots.
Topics128,090
Posts1,056,018
Members48,430
I'm pulling the wire harness out of my dash on my 59 1-ton, and i can't for the life on me figure out how to remove the headlite switch and the old cig lighter from the dash. these are the only things that i have left and i'm stopped in my tracks, my assembly manual doesn't show how to remove them, just how they are wired.
headlite sw: reach on top of it and find the little muchroom head button about middle - while pushing the button, pull the knob until the shaft comes completely out, then you can unscrew the bezel, which threads into the face of the switch case ... then it'll drop out
cig liter - there should be a sheet metal case on the back that unscrews, letting the assembly come out the front
A heartfelt thanks to you red58 for the info, i got it apart in 10 seconds! that really made my day
whad ya do for the rest of the day?
smile
Jim & Caroline
Ex Hall Monitor
Ex Hall Monitor
grin
Speaking of head light switches is there any way go get inside of them. I have one that I need to clean the contacts but it doesn’t appear that you can take the thing a part. Any help?
you might wanna reconsider taking the switch apart, or do it very slow and careful, they have lots of little bits, spring loaded, and are NOT easy to reassemble right ... more likely the springs are shot than the contacts dirty, and "stretching them back" won't last long ... the repros that are available for the 55-59 are good quality and not too spendy
I have a repro on order and it should be here tomorrow but I can never just leave well enough alone so I will take it apart and see what makes it tick.
