7 members (NJC, Gray_Ghost, GMCJammer51, Greg_H, 50Chevy3100, 1955 1 Series, 1 invisible), 74 guests, and 1 robot.
Topics128,073
Posts1,055,908
Members48,429
#469041 11/08/2008 3:28 AM
1 Offline
What is the most "reliable/leak proof" way to replace the water housing/thermostat assembly on an old GMC V6? I have always used a gasket (double coated with compound) but now see these "gasket-less" compounds on the rack at the local auto supply. Any advice welcome.
i generally have no problem's just using 3m weatherstrip adhesive on the gasket .
Riding in the Passing Lane
I always use a gasket & put RTV on both sides. If it has the therm. in a position where it could fall out, like on Fords, I glue the gasket to the housing like Old Dog does.
1972 Chevy c10 Cheyenne Super
Permatex Super Hi-Tack is what I use.
Bill Burmeister
Use that also sometimes Bill, but good old #2 Form-A-Gasket has been a staple on my shelf for more than half a century and as a professional mechanic pop used it before me. And we put many a midget back togeather using #2 and it's never failed us yet.
I probably should have used Permatex Copper Spray-A-Gasket on the head when I put it back together. But still should have RE-TORQUED IT!!!!
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
