4 members (Hotrod Lincoln, Mike B, FishinToms53, Peggy M), 91 guests, and 2 robots.
Topics128,119
Posts1,056,648
Members48,450
Junior Member
Junior Member
Is a custom transmission support crossmember necessary when installing a Saginaw 4 speed in a '50 AD 1/2 ton equipped with a stock bellhousing and an open driveline? I have read some old posts applicable to this subject, but I am still confused. All advice will be appreciated.
Denny,
Short answer is no. I have a Saginaw 4 in a 52 and its fine. If it were an aluminum 4 speed I would put one in but not a cast iron transmission. The 4 speed has a rear pad to bolt up but the crossmember would have to be moved or a short plate made.
"Drugs are money, money is power, power is security." - Kent Heiner
Nedrow population 2212
Carbon footprint family of 2/11 tonnes of CO2/yr
