3 members (Gdads51, 2 invisible),
60
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,115 Posts1,056,636 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#4685 07/04/2003 12:29 AM | Joined: Jan 2003 Posts: 43 Junior Member | | Junior Member Joined: Jan 2003 Posts: 43 | Is a custom transmission support crossmember necessary when installing a Saginaw 4 speed in a '50 AD 1/2 ton equipped with a stock bellhousing and an open driveline? I have read some old posts applicable to this subject, but I am still confused. All advice will be appreciated. | | | | | Joined: Dec 2000 Posts: 506 Shop Shark | | Shop Shark Joined: Dec 2000 Posts: 506 | Denny, Short answer is no. I have a Saginaw 4 in a 52 and its fine. If it were an aluminum 4 speed I would put one in but not a cast iron transmission. The 4 speed has a rear pad to bolt up but the crossmember would have to be moved or a short plate made.
"Drugs are money, money is power, power is security." - Kent Heiner Nedrow population 2212 Carbon footprint family of 2/11 tonnes of CO2/yr
