| | | Forums66 Topics128,154 Posts1,056,838 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 36 Apprentice | | Apprentice Joined: Jan 2008 Posts: 36 | I found this info on a Wikipidia site. Has anyone ever seen or heard of these?
1955 - 1959 - "Task Force" Production 1955-1959 Body style(s) 2-door wagon Layout FR layout Engine(s) 265 cu in V8 283 cu in V8 Engines included I-6 and the small block V-8s. Chevrolet used its 265 V-8 engine, later evolving it to a 283-cubic-inch version. GMC based their V-8 on a Pontiac design. Standard Suburban model numbers continued from the previous series, but the introduction of four-wheel-drive models in 1957 added the numbers "3156" for 4WD Suburbans with panel doors, and "3166" for 4WD Suburbans with tailgates. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | welcome to the bolt Bongo .... what is it you're wondering about, the TF designation or the different 'burb configurations? all that info and lots, lots more is available in the forums here
Bill | | | | | Joined: Jan 2008 Posts: 36 Apprentice | | Apprentice Joined: Jan 2008 Posts: 36 | I guess I was wondering is if anyone has ever seen the assigned number of 3156 or 3166 on the side of the apache fender badge. I've seen 3100 and 3600 but never the others. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the specific model designations never were on the trim pieces, just the series, 3100, 3200, 3600, 3800, etc, which indicates the weight class ... the pickup is an xx04, the panel is an xx05, etc
Bill | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The only year that the specific model number appeared on the side badge was '57, and then only on the Cameo, which was a 3124.
Bill Burmeister | | |
