BUSY BOLTERS Are you one? The Shop Area
| | Click on image for the lowdown.
3 members (68ironhead, JW51, 1 invisible),
569
robots. | Key: Admin,
Mod | | Forums66 Topics126,776 Posts1,039,271 Members48,100 | Most Online2,175 Jul 21st, 2025 | | | Joined: Oct 2008 Posts: 24 Apprentice | Apprentice Joined: Oct 2008 Posts: 24 | Hello, I have to assemble a 1952 Chevy 3100 for a friend but I have not disassembled the car so it is very complicated to assemble it sometimes. At the morment I am working at the parking brake and I wonder if there was a washer or bearing or so between the bracket and cross shaft and if the lock pin was a pin or a screw ? I took some photos : http://aol.pixum.de/album/image/id/3203657/page/1http://aol.pixum.de/album/image/id/3203657/page/2Thanks for your help Tom
| | | | Joined: Oct 2006 Posts: 9,671 'Bolter | 'Bolter Joined: Oct 2006 Posts: 9,671 | Sorry but your picture album needs a password to view it. If this is the shaft that you are talking about then to the right of the shaft where it goes through the panel there is a large washer and cotter pin that retain its side word movement. Scroll through the album, there are a lot of pictures that may be of help to you in the reassembly of the truck. Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | Joined: Oct 2008 Posts: 24 Apprentice | Apprentice Joined: Oct 2008 Posts: 24 | Hello Denny, thanks for the hint with the album here, I will looking for photos there. For my photos, perhaps this link will work : http://aol.pixum.de/viewalbum/id/3203657Tom | | | | Joined: Oct 2008 Posts: 24 Apprentice | Apprentice Joined: Oct 2008 Posts: 24 | Great ! Thank you, Denny.
Tom | | |
