10 members (MickeyP, MRMEROTH11, Gdads51, TexasJim50, 2-Ton, Southerntruck, Ponchogl, JW51, Shaffer's1950, 1 invisible),
133
Mod | | | Forums66 Topics128,132 Posts1,056,383 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2005 Posts: 738 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 738 | I have what I believe to be a 3 speed tranny from a 60's vintage 283. I am trying to get rid of it but want to be able to furnish the buyer with information.
Where on the tranny would there be casting numbers or ID Plate or something?
Thanks in advance....
Kyle
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." - George S. Patton My Machine | | | | | Joined: Apr 2005 Posts: 2,098 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,098 | Does it have the 4 bolt side cover? If it has the long tail shaft (22" overall) it could be from a 55-61 truck or 55-57 car. If it has the short tail shaft (17" overall) it could be from a 62-67 truck or 58-67 car. There is a date code on the tail housing along with some casting numbers. A date code like: A 15 0 would be Jan 15, 1960. There are some minor differences between car and truck transmissions such as the side cover and the lower mounting holes. 6 cyl and V-8 transmissions were the same in that era. Fred
| | | | | Joined: Oct 2005 Posts: 738 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 738 | Thanks, I will look it over this weekend.
