2 members (Gdads51, GrandpasJimmy), 134 guests, and 0 robots.
Topics128,191
Posts1,057,364
Members48,469
I pulled a heater out of an old 63 GMC truck.. It has three cables.. I did not obtain the dash mount unit.. I figure it's a three lever panel.. From what I've been told there is a recycling air heater and another one.. That means nothing to me.. I am in the process of installing the heater and I happened across a two lever panel.. I'm pretty sure the panel I happened across was for a standard heater.. Anyway, How do I know what heater I have aside from the dash panel? I have an opportunity to obtain a 3 lever panel but before I get it I need to know if I even need it.. I've seen these heater come in 2, 3 and 4 levers..
62 Chevy windshields rock...!!
I'm not sure about GMC's, but in Chevy's the deluxe heater is the 3 or 4 lever one, and the thiftmaster heater has one pull/twist knob that is mounted in the same location as the 3 or 4 lever panel.
IIRC, the 4 lever one is for 60-63 and the 3 lever one is for 64-66 and the one knob thriftmaster is for 60-66. Personally, I have never seen a 2 lever heater in a 60-66 truck.
If it's on full blast and you're still cold, it's not the deluxe heater.
dang
1948 Chevy 1/2-Ton
"Tuesdays with Morris"
In the Legacy Gallery
Find it - Fix it - Drive it
I have the deluxe heater.. What's the difference between using the 3 lever or the 4 lever? Will either work?? Anyone know?
I've got a 2-lever heater in my '62. I've seen lots of them.
I thought this was the "standard" heater.
The heater core, box and motor is mounted to the firewall inside the truck, under the glovebox.
One lever runs the motor: Off/Low/High
The other lever moves a cable that changes the trap door in the heater duct to defrost vents or out the end to blow heat out under the dash...and let it just sort of go where it wants to.
With this heater, there is ALWAYS hot water running through the heater core, and you can't run the defroster without running air over the heater core. It makes getting the fog off the windows in the summer a hot ordeal.
The Deluxe heater has the box, core and fan mounted under the hood. It has four levers, but I don't know what they do just yet (I have a complete system I'm going to restore for my truck). I believe with this style, you can run air thru the defroster vents or under-dash vents, without running it over the heater core.
I've never seen a 3-lever panel or system, but that doesn't mean much.
On the '60-'63 systems, the panel with the levers has four vertical slots in it, with a piece of black rubber riveted to the back side of the panel. The ones I've seen have a slit in the rubber for the levers. On my two-lever panels, the slits were not cut for the outside levers.
-Brad
SOUTHERN FALL GABfest
October 6 ~ Commerce, Georgia
Details here!
Never Pee on an Electric Fence.
