4 members (MikeE, lc_btv, Oldcaliforniakid, Rexville48), 104 guests, and 3 robots.
Topics128,050
Posts1,055,673
#46352 06/16/2005 6:32 PM
Junior Member
Junior Member
I`m looking into buying a 292 eng. out of a `67 or `68 pickup that hasen`t run for years. I would like to try to start it, and hear it run before I buy it. However someone (over the years) opened the hood, and robbed the distributor, along with the cap, and wires. My question is "will any 194, 230, 250, dist. work, or does it have to be a 292 specific dist?" Also isn`t the 235 distributor wrong for that engine? Thanks, JD
unless your the lead dog, the view never changes!
#46353 06/16/2005 9:52 PM
Riding in the Passing Lane
Any dist from a 194-230-250 will work but the 235 won,t.
1972 Chevy c10 Cheyenne Super
#46354 06/16/2005 11:09 PM
V
V Offline
Do your self a favor and find a later model HEI set up i prefer the 77-78 style with external coil but the 78 and later works just fine.these drop right into older 194_292 engines just make sure you wire it to have 12 volt power supply.once installed you wont have to touch the distributor again for a long time.
#46355 06/17/2005 7:20 AM
Or you can use an older one and install a pertronix. I have that in mine and it works well.
