| | | Forums66 Topics128,023 Posts1,055,365 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#46347 06/16/2005 12:26 PM | Joined: Jul 2004 Posts: 18 Apprentice | | Apprentice Joined: Jul 2004 Posts: 18 | I've gotten so I need to rebuild my old Rochester about once a year. She's long in the tooth, just like me. I've been thinking about going to a Holley 5200, but then .... I've been told there are bolt-on TBI kits for old Chevy sixes. Anyone have any experience with these?
'63 half-ton another '63 half-ton '62 school bus
#46348 06/16/2005 2:04 PM | Joined: Oct 2003 Posts: 363 Member | | Member Joined: Oct 2003 Posts: 363 | No experience with a bolt on kit, but I can help you build a kit from standard GM parts available at the junkyard if you want. I do lots of TBI conversions for hot rod and 4x4 guys around here, if I didn't have twins on the 39 I'd be slapping a 4v manifold and TBI on it. I put them in bunch of jeep 258s which is very similar to a 235 setup.
Here's my recipe for a stovebolt TBI system: 4 bbl manifold holley tbi adapter Wiring harness and all sensoers out of an 87-91 G series van. 747 ecm from 87-91 truck, van, astrovan with a 4.3 chip I like the 87 chevy astro van with a 5 speed chip best The chip needs to have the VSS/EGR logic removed (you can run without it removing these if you want, or a speedo adapter and leave the EGR solenoid with no hookup) Computer controlled HEI from a 250 (grind and modify to fit) Knock sensor from a computer controlled 250 O2 sensor, you can make a bung for this out of a spark plug anti fouler and put it just below the collector. Temp sensor in the thermostat housing, I have been able to use a thermostat housing with a npt port in it off a 250 on some 235s.
It can be done without all this work with a megasquirt kit, 4.3 throttle body and your vac advance distriutor. There's a guy on ebay that will sell you an already put together megasquirt for a good price (around $300).
Chris | | |
#46349 06/18/2005 7:06 PM | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | www.diy-efi.com has a lot of good info in the GM-ECM section. You can modify a standard HEI distributor for computer control, too. | | |
