0 members (), 122 guests, and 4 robots.
Topics128,184
Posts1,057,266
Members48,467
There's an accessory I'm curious about on my dads truck. It's in the cigarette lighter hole, is a lighter, but out on the end it has a light bulb, switch for the bulb, and a partial cover over the bulb. It's not in LMC or other parts catalogs. Is it 1971 original, cigar lighter, special accessory, or what? Any help would be appreciated. thanks
That's more than likely a map light.It was partly shielded so the passenger could read the map and not blind the driver.
_____________
Floyd
If we choose being kind over being right,we will
be right every time.
Knowledge is a poor substitute for experience.
Remember what is precious to another, may not be to you, but it
is precious nonetheless.
1948 Chevy 2-Ton
RT1 Offline
I have seen stainless steel cigarette lighter chart lights for boats are you sure it is not something he just picked up?
Like this: http://www.shopwiki.com/search/CIGARETTE+LIGHTER+WITH+CHART+LIGHT
Ohhh, that's it! Good job RT1! so maybe he just picked it up sometime to put in the lighter hole. is it 1971 dated? or a later doodad? THANKS! I'll get a new bulb for it if it's 1971, other wise, I'll probably pull it out and put in a lighter from 1971. Yes, the light is sheilded. You guys are good!
