7 members (Otto Skorzeny, Southerntruck, Guitplayer, Hotrod Lincoln, 52Carl, qside, 1 invisible), 160 guests, and 3 robots.
Topics128,087
Posts1,056,115
Members48,435
Apprentice
Apprentice
I'm hanging the doors on my '51 Chev (finally!) and have been working on the passenger door all day w/ my son, trying to get it to fit the opening correctly. I have a couple of problems: the door drops when you release it from latching, and the bottom of the door is out an inch or so from the bottom jamb when the door is shut. I tried bringing the top of the door out, but that just made it drop even further when shut.
The worst part is, I'm a carpenter by trade, and have hung hundreds, if not thousands, of doors in structures in my 34 years. These doors don't act right, and it's frustrating me! headscratch
Any ideas? I checked my shop manual and cab adjustment booklet, but they're very vague about such things, especially as it pertains to a COE...like it's expected that the doors will just somehow drop in! Maybe at the factory, they did...
Would appreciate any directions.
~Bruce
sounds like the door hinges are bad
I usually have a good answer on COE questions, but a problem like this taught me not to remove COE doors, if I didn't have too. I've owned over 25 COE's through the years, & removed the doors on at least four of them. Had one heck of a time getting them lined up properly, on everyone of them. I finally noticed that just tightening the doors snug, then closing them, & adjusting the gaps, as needed, then with a helper, or two, try to open them, without moving them much, so you can get your final torque, on the hinge bolts. Good hinges, are definitely, a must.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
Apprentice
Apprentice
I'm thinking the hinges are at least part of the problem. The bottom hinges on a COE also don't seem to have any in/out adjustment. I shimmed them up on each side and the doors latch better, but they still just don't fit the body the way I'd like them to. I'll start looking for a decent NOS pair and see if I can make them better.
For now, they're on, and the new weatherstrip is compressing a little. They look better ... or I'm becoming less discriminating all of a sudden!
~Bruce
I am assuming that the doors on a COE are similar to the regular cab. First you need hinges that don't have a lot of slop. In out adjustments are done by bending the hing strap. In the end the door fit will be a compromise for the "best fit".
1951 1 Ton Completed
