0 members (),
155
Mod | | | Forums66 Topics128,110 Posts1,056,241 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 73 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 73 | is the element the same as a 235? thanks. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | What year 261? And what application? I know that the later 261s with the full flow oil filters use a different element, a PF 141 (CH 200 PL in a Fram), which is the same as the V8.
Bill Burmeister | | | | | Joined: Sep 2006 Posts: 73 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 73 | 1960 c60. not sure if its full flow but i assume so.
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | OK, the C60 would use the PF141. I have the same filter housing on my 235. Should be readily available at any well stocked parts store or farm store.
Bill Burmeister | | | | | Joined: Sep 2006 Posts: 73 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 73 | thank you kind sir! OK, the C60 would use the PF141. I have the same filter housing on my 235. Should be readily available at any well stocked parts store or farm store. | | |
