3 members (Paul Mullen, JW51, GrandpasJimmy), 96 guests, and 1 robot.
Topics128,110
Posts1,056,241
Members48,437
#462804 10/18/2008 10:01 PM
is the element the same as a 235?
thanks.
What year 261? And what application? I know that the later 261s with the full flow oil filters use a different element, a PF 141 (CH 200 PL in a Fram), which is the same as the V8.
Bill Burmeister
1960 c60. not sure if its full flow but i assume so.
OK, the C60 would use the PF141. I have the same filter housing on my 235. Should be readily available at any well stocked parts store or farm store.
Bill Burmeister
thank you kind sir!
