5 members (Niels V, Phak1, MNSmith, 2 invisible),
77
Mod | | | Forums66 Topics128,180 Posts1,057,141 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#46267 06/13/2005 7:09 PM | Joined: Mar 2002 Posts: 384 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 384 | I bought a rebuilt fuel pump/vac pump. I hooked it up and my wipers did not work at all, where they used to work unless I was accelerating. Also, I started burning the oil that was sucked into my intake manifold.
I hooked it up as someone told me. I don't think it is right.
Vac side of the pump goes to the wiper. Outlet side goes to the intake manifold. It splashes oil around and it gets sucked into the intake. Blue clouds at the stop signs! Please help me with a diagram of how it should be. Thanks - Scott
55 1st Chev.
#46268 06/13/2005 8:21 PM | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Scott,
Try the outside port to the wipers and the other port to the intake manifold vacuum fitting.
If you are still sucking oil, you might have a damaged diaphragm in the pump.
Tim | | |
#46269 06/14/2005 11:18 AM | Joined: Jun 2005 Posts: 221 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 221 | if it is sucking oil from the fuel pump the pump is bad and could possibly be dumping fuel into the oil. | | |
#46270 06/15/2005 5:59 PM | Joined: Mar 2002 Posts: 384 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 384 | Thanks for both your replies. I called Arizona Vintage where I got the fuel/vac pump. They said that occasionally an oil seal not a diaphram goes. They stood behind it and I sent it back to be replaced. - Scott
55 1st Chev.
