1 members (tclederman),
94
Mod | | | Forums66 Topics128,181 Posts1,057,185 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 103 Wrench Fetcher | | Wrench Fetcher Joined: May 2006 Posts: 103 | I'm installing a newer rearend under my truck and wanted to convert from the lever shocks to the tube shocks on my '49 3/4 ton and would like to see how the factory tube shocks were mounted, or even home made mounts. If anyone has some pics that would be great!Thanks for the help! | | | | | Joined: Feb 2003 Posts: 1,381 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,381 | I do not have any pics as I went to tube shocks on my 37,I do have the rear portion of the kit from Jim Carters for the 49 on back that I am not using. I think the shocks mount on the outside of the frame rail so you will have to use the same width of rear end or that kit wont work,I put a narrower rear end in my 37 and could not use the rear part of the kit. Jeff | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 |
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | My pictures here. May Give you some ideas. Have fun and good luck Dan | | | | | Joined: May 2006 Posts: 103 Wrench Fetcher | | Wrench Fetcher Joined: May 2006 Posts: 103 | I didn't think there was even enough room to mount them outside the frame on the rear. I've got the front mounts installed but I just never saw how the rear was mounted. I like the crossmember version Chev4t6, is your truck stock height or lowered? I plan to do an axle flip and c-notch so I'm thinking the crossmember setup would be the best choice for clearance reasons. Thanks for the help guys! Any more pics are great! | | |
