6 members (tclederman, Peggy M, TexasA&M48Truck, Wally / Montana, Gray_Ghost, UtahYork), 111 guests, and 3 robots.
Topics128,066
Posts1,055,876
Members48,428
#458586 10/05/2008 5:07 AM
please, if at all possible, don't move this to the greasy spoon place. i don't like looking at all that "stuff" there. has anyone here put a 292 in a step down hudson? i finally got my hands on two 53's and i want to put a 292. if anyone has i would be interested to hear about it. hr
Is that like a Hudson Hornet? Where's the original Hudson straight six? What's the status of that?
That 292 idea of yours should work well. Don't know if you'll find very much info here on the actual specific swap you're looking at. I'm kinda thinking you're going to have to blaze your own trail there. But you should be able to get help with your 292 engine if you need it.
52 GMC 3/4 ton pickup
68 Big Block Vette
68 455 Firebird
yes it's in a hornet. the original six is gone. i, at some time, might like to rebuild a 308. but for now i just want to get her on the road. i love the 292's and have a few spares so that's what i want to use. i will prob use a chevy trans and wiring harness as well. i think i had read here that some stovebolters had hudsons and thought they might have v8's or something and they may have bought a motor mount kit or something that would at least work for a 250 and i could adapt for a 292.
sps Offline
I got some info on this sight for my 292 in my 53 P.U. This place has motor mounts that look adaptible for this. Hear it is:
Sachse Rod Shop 3904 Miles Rd. Sachse,Tx 75048 Order toll free: 18004953904 Tech & info 19724951557 Fax 19724950057 .It might help you with your Hornit Good luck, don't turnm to tight
they do great work at the Sachse Rod shop..
how come you dont like the "spoon"
Redryder pix
My Hotrod
Jim & Caroline
that looks like it might be a pretty good answer to the motor mounts and perches since the frame is a boxed one anyway. thank you all. hr
