5 members (2-Ton, Peggy M, Bill Hanlon, Woodcmiami, 1 invisible), 164 guests, and 2 robots.
Topics128,167
Posts1,057,015
Members48,458
I'm in the middle of installing a 3" dropped axle on my '49 and got to thinking if I still need to use the angled spacer (don't know what else to call it) between the springs and the axle? Thanks for the help!
It's actually a caster shim. It sets the caster setting of the axle, which the the angle from vertical that the spindle site. Very important to maintaining stability and tracking. Best would be to take it to a competent alingment shop (one that will actually do modified vehicles) and have them set it to the correct angles. You will most likely have to have the toe reset as well.
Bill Burmeister
I just had to ask a stupid question! Didn't know if I should use it becuase the axle is now much closer to the frame and didn't need that much of a angle to the axle or not. Thanks for the help!
The only stupid question is the one not asked! You'll want to hang on to those shims, they might need to use them depending on what the caster reading is. Alot will depend on how far you dropped the front compared to the rear, as that will affect overall caster readings. A little extra caster won't hurt though, as it will help stabilize the frontend, especially for highway driving.
Bill Burmeister
You'll need to put those shims back in and possibly need to add a little depending on the amount of "rake" the body has with the new axle. You can check the caster angle yourself by using an angle finder on the flat spring mount perch on the axle, which is exactly perpendicular to the kingpins. The spec for your '49 is 1 degree 15' to 2 degrees 15'. It won't hurt if your a little over these limits as longbox said, but you don't want to be under them.
Take a look at your shims, they should be marked as to how many degrees tilt they'll give. If they're between 1.5 and 3 degrees, I'll bet a dollar to a donut you'll be fine.
You can also check your toe-in yourself. Most guys chalk a line around the tires and measure carefully front to back. The spec is 1/16" to 3/16".
