| | | Forums66 Topics128,029 Posts1,055,417 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#46145 06/10/2005 12:43 AM | Joined: May 2005 Posts: 70 Shop Shark | | Shop Shark Joined: May 2005 Posts: 70 | I am going to install front disk power brakes and power steering into my '52 5 window 3100 that already has a 350 smallblock & 350 turbohydro.
I plan to use a 605 steering box and a tilt column but can't decide whether to keep the brake pedal on the floor or hand it from the firewall.
My question is with moving the master cylinder / booster under the seat so you can't check the fluid easliy.
I will appreciate input from anyone that moved the brake system to the firewall, good or bad.
Thanks---
illegitimi non carborundum
#46146 06/10/2005 9:03 PM | Joined: Aug 2003 Posts: 264 Member | | Member Joined: Aug 2003 Posts: 264 | I used a booster/MC/proportioning valve/pedal bracket from a late '80's S-10 pick-up in my 55 1st series. Not a drop-in but pretty close. Works great. | | |
#46147 06/10/2005 9:41 PM | Joined: May 2005 Posts: 70 Shop Shark | | Shop Shark Joined: May 2005 Posts: 70 | Thanks for the input. Does the frame/support assembly that hangs the pedals also tie in to the steering column mounts?
#46148 06/10/2005 10:53 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | The problem with the AD trucks is that the firewall isn't very stiff. You need to really brace the brake booster well if you are going to hang it.
