| | | Forums66 Topics128,093 Posts1,056,480 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#46052 06/08/2005 5:36 PM | Joined: Mar 2002 Posts: 384 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 384 | I read that the brake drums were the same from 51 to 1968. It got me thinking....What would be involved in converting my 55.1 from manual adjust to self adjusting brakes? Thanks - Scott
55 1st Chev.
#46053 06/09/2005 5:21 AM | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I have done this many times. I order an adjuster kit for a 1965 PU, easy swap. You should cut a new adjuster slot on the drivers side backing plate as the star wheel will now be at the back on both sides.
See the USA in your vintage Chevrolet! My Blog | | |
