| | | Forums66 Topics128,030 Posts1,055,423 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2008 Posts: 71 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2008 Posts: 71 | I turned on my headlights after I finished the tank install on my truck, and my pass. headlight was out. I checked it, it's connected. I had to disconnect the taillights to lift the bed, but there's only one way to connect them, and they're connected again. I did not mess with any wiring other that that, connected the existing sender wire and ground for the tank, so I didn't have to mess with any new wiring.
So, just before I decided to buy a new headlight, I tried my brights. Both headlights go out! Dims, driver's side works, brights neither. Tails, blinkers, and front markers/blinkers work, just the headlights don't.
I'm confused, please help!
thanks, Tony
Wide open 'til you see God...
Then brake
'64 Stepside 355, 700R4, 10:1 C/R, TCI Streetfighter, Thumper Cam, Hedman Hedders, starting wiring and bodywork shortly, W.I.P. '07 Charger 3.5L '99 Dodge Ram 1500 Ext. Cab 360 4x4 (Sold) '07 F@#$ Focus ST (Sold)
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Tony,
The high beam and the low beam aren't on the same circuit. My wild guess is that the passenger side lamp is actually burned out and the high beams don't work because the dimmer switch is funked up...two different problems.
I think your truck has plugs/connectors for many of the circuits. Could one of those have been pulled loose in your wiring efforts.
The passenger side light, both high and low, series through the drivers side light. Rattle the dimmer a bunch of times and see if the lights magically come on (hi).
Stuart | | | | | Joined: Aug 2008 Posts: 71 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2008 Posts: 71 | Thanks for the ideas and the info, Stuart. I did the whole rattle-shake to the dimmer, it worked last week and before flawlessly. I don't really know how old it is, but it looks fairly new. I'll double check the connections. I'm going to run thru the whole setup tomorrow, hopefully it's nothing major, but it still really weirds me out. I'm not sure if i can get myself to believe that the circuit for the brights would just go out like that. I know, they probably do it all the time, but it just doesn't seem like it's the answer.
Any other suggestions/ideas are welcome, too. Thanks, Tony
Then brake
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Weird problems often turn out to be a grounding problem of some sort.
I'd use a jumper between the negative lead on the battery and the ground pen on each headlight, maybe both at the same time, and see if that changes what is happening.
If that does make it work right you then would need to determine which ground is not working.
And maybe its something else entirely, but weird problems often seem to be ground problems so I'd check that first.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Aug 2008 Posts: 71 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2008 Posts: 71 | Thanks Steve. Another good idea for me to poke around with tomorrow.
Gotta say, I love that you guys are so willing to share ideas, I sometimes get stuck and overlook simple things, and it helps to be reminded. I once did a real stupid and sold a buddy my 80 pickup, couldn't get it to run right...
Turns out after I changed all the ignition components, messed with the carb adjustments, he got it and connected the BRAKE VACUUM HOSE and it ran awesome again... He wouldn't sell it back to me, you'd think I'd learn haha.
Then brake
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Troubleshooting electrical systems is so much easier if you have a multi-meter. It will tell you where you are getting power and where you're not, and if your ground is good or not. Even a cheap one will do the trick. | | |
