| | | Forums66 Topics128,041 Posts1,055,479 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2002 Posts: 83 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 83 | Maybe I am a little thick, but I am just not getting the picture here. I have never timed a chevy 6 cylinder engine and so I have searched this forum and read through my shop manual and still have a timing quesion.
I understand the basic procedure for timing a 235 engine. What I have not been able to pin down is where on the bell housing you are looking to point your timing light? In some posts they talk about the hole on the drivers side of the bell housing on the front of the BH. But you also have the cover on the top of the BH between the engine and the tranny that allows you to see the flywheel. The triangle marking on my flywheel is on the rear side of the flywheel, which would indicate you have to point your timing light at the rear side of the flywheel. So then if I am using the cover on the top of the BH then where is the indicator mark to line up the triangle with?
Confused, but still asking....
Thanks, Chevman | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | There is a opening in the bell houseing just above the starter. When fireing #1 or #6 a steel ball should apear in the flywheel.This is the timing mark. You can usually advance it a few degrees further. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I've also read the posts saying the mark is on the driver's side. That is incorrect as Wrenchbender said. If you don't like standing on your head to get the correct viewing angle you can time it using a vacuum gauge.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Dec 2006 Posts: 1,154 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,154 | Its a PIA...but just look above the starter and there is a small hole you can see the fly-wheel. Best is thing is to clean the fly-wheel off and mark the ball with a white paint or correction fluid. Mark the timing pointer also with white paint. Dizzy turned CW is advance or BTDC turned CCW ATDC time it to the ball and go from there with your highest vacuum 17 to 21 back off a pound and you are good to go. The triangle is not the timing mark as pointed out here in the forum to me. This mark is to set-up the valve gear. Look for a small indented single metal BB its much smaller than what is used in a BB gun. I learned all this from this forum. These guys are the best. Like you I'm (still) confused but willing to learn. SJB | | | | | Joined: Mar 2002 Posts: 83 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 83 | Thanks for the clarification and the pictures!!! This web site and its members are the best!  | | |
