7 members (Wickedbass, JW51, Maybellene, Hotrod Lincoln, MNSmith, 2 invisible), 95 guests, and 3 robots.
Topics128,042
Posts1,055,595
#456008 09/26/2008 12:55 AM
Apprentice
Apprentice
I have 1967 chevy C20 truck. I have swapped in a front crossmember assembly from a 1972 truck. Now I have disc brakes and I have added disc to the rear. I need a power booster and master cylinder. I have order a proportioning valve from willwood to compensate for the rear. My question is will a 79 chevy truck system work or should I lok for something else?
Nick
In reading your questin I'm not sure what you need. 79 Chevy truck system for what? You have 72 front disks, and something unknown in the rear, yet disk. That being the case, I would look into late model pickups master cylinders since they usually come that way.
Devin
If you can't hose it out it ain't a truck
55 3100
63 Corvair Monza
64 El Camino
72 240Z
01 Suburban
You might consider using a '65-'82 Corvette master cylinder, which is what is used in most aftermarket conversions.
Bill Burmeister
