2 members (Dennys28, 1 invisible), 93 guests, and 3 robots.
Topics128,059
Posts1,055,818
#456043 09/26/2008 3:13 AM
hi all -- finally have the engine unstuck and moving -- I have the rocker arm assembly rebuilt; valve job pending, but probably this weekend! Almost there! Anyway, three quick ones, hope not too dumb:
1. how hard should it be to turn the engine by hand? -- I used a bar on the flywheel; it took some serious effort, but it worked; I now have the flywheel off and am cleaning everything; there is no way I can turn it from the side with the balancer, and I mean No way. that normal?
2. now that the engine turns, how long will it stay unstuck? do I need to move fast to finish the job so it does not lock up again? keep the cylinders lubricated?
3. I want to trash the transmission for a 3 or 4 speed on-the-floor -- any recommendations? -- Hershey is next week - will be able to buy what I need --
thanks all -- really appreciate you guys -- chris
Mines rebuilt and even without plugs I can't turn it over by hand..at least not easily..Give it a little oil and you should be good for a long while
Keith
jdl Offline
I can turn mine over a little by using the fan an putting a little pressure on the belt, but it isn't very easy and I don't do it anymore since I only needed to do it twice to see if the engine was stuck and to disengage the starter.
Jordan D. Long
1954 Chevrolet 3100 1/2-Ton
And some more pictures
Photobucket
I got a 'Possum Pickup... Now I'm the Roadkill King!!! Anyone want to make some Stovebolt Stew?
