| | | Forums66 Topics128,038 Posts1,055,585 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2006 Posts: 38 Apprentice | | Apprentice Joined: Apr 2006 Posts: 38 | I have 1967 chevy C20 truck. I have swapped in a front crossmember assembly from a 1972 truck. Now I have disc brakes and I have added disc to the rear. I need a power booster and master cylinder. I have order a proportioning valve from willwood to compensate for the rear. My question is will a 79 chevy truck system work or should I lok for something else?
Nick | | | | | Joined: Jan 2008 Posts: 239 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 239 | In reading your questin I'm not sure what you need. 79 Chevy truck system for what? You have 72 front disks, and something unknown in the rear, yet disk. That being the case, I would look into late model pickups master cylinders since they usually come that way.
Devin
If you can't hose it out it ain't a truck
55 3100 63 Corvair Monza 64 El Camino 72 240Z 01 Suburban
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | You might consider using a '65-'82 Corvette master cylinder, which is what is used in most aftermarket conversions.
Bill Burmeister | | |
