0 members (), 125 guests, and 2 robots.
Topics128,136
Posts1,056,425
Members48,441
Apprentice
Apprentice
The master cylinder on my '58 Apache will need to be rebuilt/replaced before I can put it back on the road. I was thinking that it would be prudent to use this opportunity to convert it to a dual circuit system.
I am looking at this kit from American Classic: http://www.americanclassic.com/images/BR0105-DB.jpg
Do I have to install a proportioning valve with this system? Or do I simply plumb the front brakes to one side and the rear brakes to the other side?
Tony Kimmell
1958 Chevy Apache
1982 Ford F-150 4x4
2005 Chevy Impala
2005 Chevy Uplander
If all you are doing is replacing your original with the unit from Americal Classic; plumb the fronts together and the rears together. Each circut will need a 10# residual valve. The MC may have built in residual valves, in which case you do not need to install inline valves.
Here is the url for one of the best articles on automotive brakes that I have ever read.
http://www.hotrodheaven.com/tech/brakes/brakes9_index.htm
best wishes,
Les
Check out CPP before you decide. These guys have dozens to choose from, drum,drum or drum,disk or disk,disk
http://www.classicperform.com/4754chevtrk.html#Master%20Cylinder%20Kits
~Jim
