| | | Forums66 Topics128,187 Posts1,057,316 Members48,468 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2007 Posts: 22 New Guy | | New Guy Joined: Aug 2007 Posts: 22 | Hi all,
I've finally got my 51 4400 road worthy after most of a year and have had a chance to drive it a bit. It's apparent after driving it a bit that the overdrive tranny I had planned for it would be useless without more power. I'm having to downshift a lot to take hills and with overdrive I wouldn't be able to maintain highway speed on much of a grade. Is this typical? The engine is a '58 235 and has good compression, no smoke, and good oil pressure.
My question is whether there would be anything gained with multiple single barrel carbs (or perhaps an Offy/Holley 390) on a vehicle this heavy (5600lbs)? I'd like to keep this engine, as it's in such good running condition but I need to be able to drive it on the highway (55 mph) for it to be useful. I don't need to go fast, just get it up to speed and hold it there.
I'm going to have my friend put it on his Sun engine analyzer to make sure that timing, ignition, fuel ratio, etc are OK. Hopefully, there's a bit more power to be gained through tuning.
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | I think that your wishing for more speed than your truck is going to allow because of the rear end gear ratio. Back when these trucks were new most of the speed limits for trucks was 45 mph tops. My '53 6400 is happy as can be going 45 mph. If I have to pull a hill with lots of grade I usually will drop a gear, or at least shift the 2 speed into low range.
Don | | | | | Joined: Nov 2004 Posts: 338 'Bolter | | 'Bolter Joined: Nov 2004 Posts: 338 | An improved carb setup and headers will definitely give you more power out of a 235.
Without the overdrive it won't matter, as Don states the gearing will keep it around 45 mph.
If you do the overdrive keep in mind how your going to stop the darn thing. That's one I haven't figured out yet so I just drive 45 and keep to back roads. | | | | | Joined: Aug 2007 Posts: 22 New Guy | | New Guy Joined: Aug 2007 Posts: 22 | If you do the overdrive keep in mind how your going to stop the darn thing. That's one I haven't figured out yet so I just drive 45 and keep to back roads. Yep, that's definitely still on the top of the agenda. After I've gone through all the brakes on this thing, it's not too bad... if you're Paul Bunyan. A power brake conversion is the next thing I'm working on. I'm going to fab up a bracket and mount a 9 inch dual diaphragm booster with a drum/drum 1 1/4" dual master cylinder on the frame rail. If anyone is interested, I can probably dig up the part number for that MC. | | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | I have plenty of power but the rear axle gearing(2 speed rear axle big bolt) doesn't allow me to use what power I have with one carb. I'm going to say two is just a waste of fuel and money. just my opinion.. | | | | | Joined: Feb 2004 Posts: 29,881 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,881 | If anything, the dual carb setup will make the problem worse, not better. The only place you'll gain any improvement will be at maximum RPM, and once the engine lugs down, even a little bit, the power will simply evaporate. If you want a little more carburetor, you might consider going to a 2-barrel Rochester like the one that was used on a 265 or 283 V-8. (Not the bigger 2GC model used on Pontiac engines, Chevy 350's, etc.) Even that one would require some major machining and welding to the manifold for a proper-sized flange to eliminate the choke point that would be created by using an adapter plate.
Bottom line- - - - -pick a gear that lets you pull the load without downshifting any further, and keep the RPM's up near the maximum horsepower point. That's probably close to 4,000 RPM, maybe a little less. If you can stay at the max-HP engine speed without losing road speed, that's all the performance you're going to get, regardless of the carburetion you have. Any more power will require a bigger engine (261), more compression, or a camshaft that's able to produce more bottom-end torque. Jerry
| | | | | Joined: Jan 2006 Posts: 19 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 19 | I was never a believer in aluminum intakes or headers until my son's 85 Ford F-250 4 x 4 with a 300 6 developed carburator / computer problems. We didn't want to buy a new 1 bbl and deal with the computerized carburation crap, so we replaced it with a Clifford 4 bbl intake and headers that we found used, and a new Holley 4160 390 cfm carburator. Fuel mileage was about the same, but the truck ran much better with alot better acceleration and alot more power. In fact it would spin the tires in 3rd gear on pavement if you got on it. We're planning on doing the same thing to his 69 Ford 240 this winter. They sell stuff for Chevys too. I think everything they sell is for inline engines. They sell direct. www.cliffordperformance.net | | |
