| | | Forums66 Topics128,161 Posts1,056,958 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#45353 02/05/2005 1:59 AM | Joined: Jun 2004 Posts: 40 Junior Member | | Junior Member Joined: Jun 2004 Posts: 40 | I have a 46 3/4 ton/ I am getting some conflicting information and need help.
2 suppliers say that the cups for the 1/2 and 3/4 ton drag links are the same. But they say that the balls are differnt. (not sure how or why, my main suppler is out of them to compare)
I ended up with 2 sets of tie rod end balls ( bolt on type) The look like they will fit on the drag link. The cups fit in the holder. It looks like the cups are the same, and the lenght of the ball is about the same and look like they will fit. There is room for the nuts to clear the I beam. Teh nut on the stearing arm has plenty of room.
can I use the bold on tie rod ends and cups on the drag link????
Better ask before I drill out the old one and get stuck.
Ted Wilson
