7 members (3B, Tinker5, Gdads51, Bill Hanlon, Bills Auto Works, WICruiser, 2-Ton),
135
Mod | | | Forums66 Topics128,195 Posts1,057,378 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#45331 08/29/2003 2:56 AM | Joined: Jul 2003 Posts: 101 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2003 Posts: 101 | I got a good deal on a 1953 GMC 302 hoping to replace the stock 228 in my 51 GMC 1-ton. The 302 came with a bellhousing, 6 bolt flywheel, clutch, and pressure plate. The problem is that the bellhousing wont bolt up to the SM420. The top holes on the bellhousing are ~7.75" apart, bottom are ~ 7.25 apart. On the SM420 the top holes are 8.25 apart, bottom 9" apart. I cant use the 228 bellhousing because it isnt as deep as the bellhousing that came with the 302, so that there isnt room for the 302 pressure plate. I also cant just use the 228 flywheel and thinner pressure plate with the 228 BH (having the correct bolt pattern) because the 228 FW is 4 bolt and the 302 FW and crank are 6 bolt.
Any Suggestions
Izzenhood | | |
#45332 08/29/2003 3:54 AM | Joined: Aug 2000 Posts: 197 Member | | Member Joined: Aug 2000 Posts: 197 | You probably have the bellhousing to fit the clark transmission. Here is an old trick to use the stock 302 pressure plate with the 228 bellhousing: Put the pressure plate on a drill press and use the chuck and a spare throwout bearing to press the diaphragm down as if you were disengaging the clutch. Put washers between the diaphragm and the pressure plate housing to keep it compressed. Install clutch and tranny, remove washers. It worked when installing my 302. You also should be able to do a minimal amount of grinding to make the pressure plate fit without doing the washer trick.
Jason
#45333 08/30/2003 2:54 AM | Joined: Jul 2003 Posts: 101 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2003 Posts: 101 | Jason
Sounds like a good plan. We'll try the washer trick and let you know how it went.
Thanks for the help
Izzenhood | | |
#45334 09/02/2003 3:13 AM | Joined: Feb 2000 Posts: 587 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 587 | I have a Clarke trans from a COE, free, you pick-up. It has forward facing shift lever and taller tower, so it won't work either, darn!!!! :p
G.L. Grumpy's Old Iron Ranch Huntington, IN 46750
MM R tractor, Speedex and Power King tractors
