4 members (Phak1, 2-Ton, Gdads51, Wayne67vert), 36 guests, and 1 robot.
Topics128,022
Posts1,055,360
Members48,420
#452905 09/16/2008 12:36 PM
i have a 52 1ton 3800 all the replacement glass i have found only goes to 3600 series are the windows the same? the cab i believe is the same as a 3600,but have been wrong before thanks for your help
trying #452914 09/16/2008 1:28 PM
You are correct. The cabs and doors are the same.
David Colter
pics * 1954 wrecker * [color:#009900]1948 Chevy 1-Ton[/color]
54TOW #453005 09/16/2008 7:17 PM
Isn't the glass all flat? Unless it's a 5 window. Flat glass can be cut at any autoglass shop. If you have any local shops I would check it out. You save on shipping also. Have fun and good luck
Dan
