4 members (Shardean, Tstan7, 2 invisible), 94 guests, and 4 robots.
Topics128,022
Posts1,055,353
Members48,420
#452888 09/16/2008 6:51 AM
I've got a 59 in really good shape, but want to do a complete restoration. I found a 58 parts truck and I was thinking on buying it to strip down to the frame and rebuild it back up using the parts off the 59 (partly to see how things go back together once I take them apart). They are both long beds but one is a step side and the other is a fleet......the frames should be the same shouldn't they? Any thoughts on doing this or should I stick to just tearing down/rebuilding one truck?
the trucks will be identical except the beds and the badge trim .... get an assembly manual to see how things go together - get both, refurbish the "really good" one, restore the one that needs it .... a relatively unmolested original is much preferable to one [or 2] that's been stripped to the frame .... and way less spendy
If it ain't broke, don't fix it.
1951 3800
-hotshoe
I would drive the 59 and restore the 58. Those frame off can take years and lose steam after a while. Then if you want, restore the 59.
And look out for folks beating down your doors trying to get an original set of fender spears.
...other than that, what Red58 said: restore the "good" one and make another one with the leftovers. Sell the one that speaks to your wallet louder than your heart.
