| | | Forums66 Topics128,021 Posts1,055,351 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2008 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2008 Posts: 46 | i have a 52 1ton 3800 all the replacement glass i have found only goes to 3600 series are the windows the same? the cab i believe is the same as a 3600,but have been wrong before thanks for your help | | | | | Joined: Feb 2008 Posts: 829 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 829 | You are correct. The cabs and doors are the same. | | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | Isn't the glass all flat? Unless it's a 5 window. Flat glass can be cut at any autoglass shop. If you have any local shops I would check it out. You save on shipping also. Have fun and good luck Dan | | |
